FM5 - Bathurst 1000 *Idea*
+2
6 posters
Bathurst 1000
OZFM Endurance Series
Open to 16 cars with 32 drivers.
Each car will have 2 drivers:
* 1 x Pro Driver (regular lobby 1 driver)
* 1 x Pro-Am Driver (regular lobby 2 driver)
** There will be NO Pro/Pro pairings. Only a Pro/Pro-Am pairing will be allowed. A Pro-Am/Pro-Am pairing will also be allowed. Current lap times and previous V8 series results will be referenced for those wishing to "sand bag" in an attempt to get two Pros in the same car.
Each driver must run at least one stint but no more than three stints.
Race will be run over four nights with 40-41 laps each night to make up the 161 laps/1000km. These night will be the driver stints. Qualifying will be held the week prior.
Cars will need to pit at least once each stint for tyres and fuel (plus any mechanical repairs).
At the end on the 40-41 laps that stint will be over. The next 40-41 laps will start under the Safety Car with all cars on new tyres, full fuel and full repairs. first lap will allow all drivers to return to their finishing position from the last stint and drive single file to the last corner where the race will re-start. Cars lapped previous stint can unlap them selves and return to the end of the line.
First lap will be a formation lap to sort grid positions made from qualifying then a standard grid start.
All other stints will be a rolling start behind the lead car at Safety Car pace till the final corner.
End of each stint will determine your position for the next stint.
The end of the final stint will give us our final positions and winners.
Qualifying will be done on a separate night(s).
The Car:
2011 V8 Supercar (Dunlop Series Spec)
Ford Falcon or Holden Commodore
Allowable upgrades:
* Adjustable Brakes will be added.
* All other parts are to remain Stock.
** Once available the COTF cars will replace the older spec cars with the same restrictions.
Tuning restrictions:
* Gears will be locked for ALL cars and set to the official settings for Mt Panorama as written in the official V8 Supercars rule book.
* Aero will be locked to the default angle.
* All Suspension parts are free to tune.
* Differential is free to tune.
* Tyres pressure can be adjusted.
* Brakes can be adjusted.
Additional Tuning Restrictions...
* Suspension parts and differential to be adjusted prior to the Race and must not change during the entire 161 laps. Minor changes may be allowed for teams using controllers and wheels.
* Brakes and tyre pressures can be adjusted at each driver change (set to the drivers needs for their stint).
* Drivers found braking the rules may find their car Black Flagged or forced to take a Drive Through Penalty (to be taken after formation/safety car lap at the start of the stint. This will not count as the compulsory pit stop).
Drivers Briefing:
* All drivers must read and abide by the OZFM Drivers CoC.
* Race Stewards could be asked to review video footage after each stint and pass out penalties if required.
Livery:
* One livery for two drivers.
* Custom liveries will be allowed. Painter to share design for drivers to use.
* Replica liveries will be allowed however only one of each allowed on track.
* Designs that breach the ToC and CoC of OZFM, T10 and M$ will not be allowed.
* Stock rims can be painted in FM5.
* Race numbers will not be required. If the livery is your creation the Pro Drivers number should be the one used.
Assists:
* Assisted steering and braking will not be allowed.
* All other assists will be open but may change prior to the event.
Time Table:
Week One
Night A: Test session, pre qualifying
Night B: Test session, Shoot Out (1 out lap, 1 fast lap)
Week Two
Night A: First stint 40 laps.
* A single parade lap will be used to sort the grid order.
* Lobby will re-start with correct grid positions for standard grid start.
* 40 laps ends and final positions recorded.
Night B: Second Stint 40 laps.
* A single parade lap will be used to sort the previous finishing order.
* First lap will be under Safety Car and drivers will for a single line ready for a restart. Safety Car lap will count as a lap.
Week Three
Night A: Third Stint 40 laps.
Night B: Final Stint 41 laps.
* After the 41 laps the race will be over and the final positions will give us a winner.
When to run:
To be run over two night in a week. Tuesday should be one of the nights. Once drivers are sorted the second night can be set. Maybe Monday, Wednesday or Thursday.
Would like to hold the event till wheels are sorted to make it fair for all drivers.
If the event works we might try to incorporate it into the full V8 Supercar series as the final event. We could use the leaderboard to pair the drivers. #1 pared with #32, #2 paired with #31 and so on. Personally the original pairing option might be best.
Let me know your thought on this.
The same concept could be used for other endurance events like LeMans, Spa and Nurberg (when released) but could include more drivers per car.
Additional:
Gear Ratio
1st: 2.57
2nd: 1.99
3rd: 1.60
4th: 1.35
5th: 1.14
6th: 1.00
These are set by V8 Supercars Australia and used for the Dunlop Series (Pre-COTF spec chassis). They are also the Default ratios in the game.
Final Drive for Bathurst
3.15
This will lower the default top speed from 300 to 299 but it is the actual ratio used for the Bathurst circuit and what we will use for the event.
Future V8 events should also run the same rule for the gear ratios. Only the final drive will be changed. FM4 only allowed final drive changes but FM5 has full gearbox adjustability. Those clocking 300km/h at the Chase without drafting may be seeing the stewards...
Dunlop Series Rules
V8 Supercars Ops Manual
The Car:
Allowable upgrades:
Drivers Briefing:
Livery:
Assists:
Time Table:
Week One
Week Two
Week Three
When to run:
Additional:
Gear Ratio
1st: 2.57
2nd: 1.99
3rd: 1.60
4th: 1.35
5th: 1.14
6th: 1.00
3.15
Dunlop Series Rules
Re: FM5 - Bathurst 1000 *Idea*
Dektra signing up. Not sure what group I'll be in
No sign ups just yet. Still in the planning stage and seeing if it will actually work. More for the interest and comments right now.Dektra wrote:Dektra signing up. Not sure what group I'll be in
As for groups... It looks like almost all the OZFM crew on FM5 have run a stock V8 around Bathurst and clocked a time. The S class leaderboard may come in very handy along with qually and race results from previous V8 series.
Sounds great. I like how its organised over the 4 weeks but can the first 40 laps be included in the qualifying? Not much racing that first week otherwise!
lol, are you a lawyer?Each driver must run at least one stint but no more than three stints.
ThousandSumo- Serious Racer
So 40 laps would be what, a bit over an hour and a half?
Sounds like a real challenge.
original skin- Serious Racer
How about a full v8 series on a few tracks
Sounds great. I'm keen for it if I get a XBONE in time.
Also, I have a killer track list for when the V8 Series kicks off
JamieWhincup#1- OZFM Legend & Hall of Famer
» FM5 Touring Car Masters *Idea*
» FM5 V8 Supersedans *Idea*
» FM5 - Super Taikyu *Idea*
» Super 2000 Classics *idea*
» OZFM SuperSaloons --- Idea
