NGTC Car Builds
NGTC Car Builds
All Builds are in Beta Testing.
[You must be registered and logged in to see this link.]
I was hitting 1:03.0xx around Silverstone National in all of these builds.
2011 Alfa Romeo Giulietta Quadrifoglio Verde
Engine And Power:
Race Intake
Street Exhaust
Sport Valves
Race Engine Block
Race Pistons And Compression
Race Intercooler
Race Oil And Cooling
Race Flywheel
Platform and Handling:
Race Brakes
Race Spring and Dampers
Race Anti-roll Bars
Race Roll Cage
Sport Weight Reduction
Transmission:
Race Clutch
Race Transmission
Street Driveline
Race Differential
Tires and Rims:
Race Tire Compound
255 Tire Width
O.Z Racing Superturismo GT
19 Inch Rims
B-584
229 kw (307 HP)
452 Nm (333 LB-FT)
1,270 kg (2,800 lbs)
Race Intake
Street Exhaust
Sport Valves
Race Engine Block
Race Intercooler
Race Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Street Driveline
Race Differential
Tires and Rims:
Race Tire Compound
255 Tire Width
19 Inch Rims
B-584
229 kw (307 HP)
452 Nm (333 LB-FT)
2013 Ford Focus ST
Engine And Power:
Sport Fuel System
Sport Exhaust
Race Valves
Street Oil And Cooling
Sport Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Sport Driveline
Race Differential
Tires and Rims:
Race Tire Compound
245 Tire Width
B-574
222 kw (298 HP)
434 Nm (320 LB-FT)
Sport Fuel System
Sport Exhaust
Race Valves
Sport Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Sport Driveline
Race Differential
Tires and Rims:
Race Tire Compound
245 Tire Width
B-574
222 kw (298 HP)
434 Nm (320 LB-FT)
2007 Honda Civic Type-R
Conversion:
Aspiration Conversion - Single Turbocharger
Engine And Power:
Sport Exhaust
Sport Pistons
Sport Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Race Driveline
Race Differential
Tires and Rims:
Race Tire Compound
235 Tire Width
19 Inch Rims
B-569
203 kw (272 HP)
265 Nm (195 LB-FT)
Engine And Power:
Sport Exhaust
Sport Pistons
Sport Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Race Driveline
Race Differential
Tires and Rims:
Race Tire Compound
235 Tire Width
19 Inch Rims
B-569
203 kw (272 HP)
265 Nm (195 LB-FT)
2010 Renault Megane RS 250
Engine And Power:
Race Air Filter
Race Fuel System
Race Ignition
Race Exhaust
Race Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Race Driveline
Race Differential
Tires and Rims:
Race Tire Compound
245 Tire Width
19 Inch Rims
B-584
232 kw (311 HP)
423 Nm (312 LB-FT)
1,292 kg (2,848 lbs)
Race Air Filter
Race Fuel System
Race Ignition
Race Exhaust
Race Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Race Driveline
Race Differential
Tires and Rims:
Race Tire Compound
245 Tire Width
19 Inch Rims
B-584
232 kw (311 HP)
423 Nm (312 LB-FT)
2012 Vauxhall Astra VRX
Engine And Power:
Sport Valves
Race Intercooler
Race Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Race Weight Reduction
Transmission:
Race Clutch
Race Transmission
Race Differential
Tires and Rims:
Race Tire Compound
255 Tire Width
B-576
220 kw (295 HP)
427 Nm (315 LB-FT)
Sport Valves
Race Intercooler
Race Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Race Differential
Tires and Rims:
Race Tire Compound
255 Tire Width
B-576
220 kw (295 HP)
427 Nm (315 LB-FT)
2011 Volkswagen Scirocco R
Engine And Power:
Sport Intake
Street Valves
Race Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Race Driveline
Race Differential
Tires and Rims:
Race Tire Compound
235 Tire Width
B-570
204 kw (273 HP)
366 Nm (270 LB-FT)
Sport Intake
Street Valves
Race Flywheel
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Race Driveline
Race Differential
Tires and Rims:
Race Tire Compound
235 Tire Width
B-570
204 kw (273 HP)
366 Nm (270 LB-FT)
2011 BMW 1 Series M Coupe
Engine And Power:
NIL
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Race Differential
Tires and Rims:
Sport Tire Compound
265 Tire Width
19 Inch Rims
B-553
250 kw (335 HP)
451 Nm (332 LB-FT)
1,389 kg (3,064 lbs)
NIL
Race Brakes
Race Anti-roll Bars
Race Roll Cage
Transmission:
Race Clutch
Race Transmission
Race Differential
Tires and Rims:
Sport Tire Compound
265 Tire Width
19 Inch Rims
B-553
250 kw (335 HP)
451 Nm (332 LB-FT)
2010 Mazda 3
Engine And Power:
Sport Fuel System
Sport Ignition
Race Intercooler
Race Flywheel
Platform And Handling:
Race Brakes
Race Suspension
Race Roll-Bars
Race Roll Cage
Drivetrain:
Race Clutch
Race Transmission
Race Differential
Tires And Rims:
Race Tire Compound
245 Tire Width
Oz Racing SuperTurismo GT
19 Inch Rims
B-575
224 KW (300 hp)
434 Nm (320 LB-FT)
1,270kg (2,800LBS)
Sport Fuel System
Sport Ignition
Race Intercooler
Race Flywheel
Race Brakes
Race Suspension
Race Roll-Bars
Race Roll Cage
Drivetrain:
Race Clutch
Race Transmission
Race Differential
Tires And Rims:
Race Tire Compound
245 Tire Width
19 Inch Rims
B-575
224 KW (300 hp)
434 Nm (320 LB-FT)
1,270kg (2,800LBS)
Re: NGTC Car Builds
Can someone please make a folder for this series, move this in there, lock the thread, create a new thread in the folder call NGTC - Build Discussion, and link the relevant section in the round 6 OP to that folder
» NGTC - Round 4 - Indianapolis GP (9-1-16)
» OZFM NGTC Giveaway
» NGTC - Build Discussion
» NGTC - Round 5 - Sonoma GP (16/1/16)
» NGTC - Round 3 - Hockenheim National
