Cant use the clutch pedal
Hi all, I dont no if its just me but I cant get my clutch pedal to work on FM4. Im using the porsche turbo S with the clubsport pedals. Is there a trick to getting it done?
Re: Cant use the clutch pedal
It may be the sequence you are starting things up.
1. Turn on Xbox
2. Turn on wheel
3. Connect wheel
4. Start the game
Do not turn on the xbox with the wheel.
1. Turn on Xbox
2. Turn on wheel
3. Connect wheel
4. Start the game
Either that or the in game options.
Make sure you're got the settings to "manual with clutch".
Sorry if thats abit obvious.
Thanks for the help guys. The clutch is working now
It was either 1 of 2 things
1: I downloaded the game to a usb stick, not my hard drive
2: the update might of fixed it.
I deleted the game off the usb and put it on the hard drive and at the same time It recived the update and after that it worked
Just stating the obvious here,
But, periodically check all PS2 conectors to and from the pedals. Make sure they are always fitting very firm, as a loose connection will efect the wheel and it functionality.
» PE RACING PEDAL BOX FOR MY MR2
» FM6 - Launching with clutch
» Manual Clutch on controller
» Launching with Fanatec - clutch + shifters
» Strange Fanatec clutch Wheel issue.
