Launching with Fanatec - clutch + shifters
Post by FrankTank on Sat Oct 15, 2011 9:25 am
I've been having a go at rivals mode - and I've noticed that when I use the 6+1 shifters I can never get the car off the line properly..
I don't normally notice, because I'm terrible at launching a car, but it's really obvious in the Top Gear rivals challenge, because is a stationary start.
If I don't have the shifter plugged in when I turn the wheel on the game will automatically manage the clutch at launch. If the shifter is plugged in then the game makes you use the clutch to launch, but I can't manage to do it fast enough to keep up to a game assisted launch, and if you try and start to release the clutch before the 3,2,1 countdown is finished you just get gearbox damage, and it's even slower.
Does anybody have any insight? is there something I'm missing - or am I just terrible at using the clutch off the line?
Re: Launching with Fanatec - clutch + shifters
Post by original skin on Sat Oct 15, 2011 9:44 am
It's probably your throttle control that is at fault, not clutch.
Post by mcrow5 on Sat Oct 15, 2011 10:22 am
original skin wrote:It's probably your throttle control that is at fault, not clutch.
this is probably your problem Frank.
with the SIARPC top gear challenge, i just floor it, i do not back off the start and have found it to be pretty good so far.
Post by Dazza4610 on Sat Oct 15, 2011 10:59 am
If you use the sequential shifter then it will just take off fine without the clutch on GO, but if you use the H pattern shifter, you will need the clutch to launch or you will damage the gearbox. I have found with the H pattern the race starts in N so you need to shift into 1st then drop the clutch on the GO.
If you have the H pattern shifter attached and you are using the paddles then you will have the same problem as you do with the H pattern only.
Using simulation steering I have pretty much gone to the paddle shifters, bit hard to take you hand off the wheel even for a second, I am constantly correcting something lol.
Post by RRT_DemoN on Sat Oct 15, 2011 3:46 pm
i have a quick question on this subject can u ride the clutch like real driving or is it only engaged or disengaged cause this will be a big reason of getting a fanatec wheel and cluuby pedals set
RRT_DemoN
Post by Dazza4610 on Sat Oct 15, 2011 3:50 pm
You can ride the clutch ... And it doesn't wear out Smile
Post by RRT_DemoN on Sat Oct 15, 2011 3:54 pm
cheers dazza with that news i think ill get one to teach the missus how to drive without riding the clutch will save me $$ in the long run Razz
RRT_DemoN
Post by iWolf on Sat Oct 15, 2011 3:58 pm
RRT_DemoN wrote:cheers dazza with that news i think ill get one to teach the missus how to drive without riding the clutch will save me $$ in the long run Razz
Good luck with that, lol.
Post by FrankTank on Sat Oct 15, 2011 6:22 pm
Dazza4610 wrote:If you use the sequential shifter then it will just take off fine without the clutch on GO, but if you use the H pattern shifter, you will need the clutch to launch or you will damage the gearbox. I have found with the H pattern the race starts in N so you need to shift into 1st then drop the clutch on the GO.
Thanks Dazza - I'm pretty sure that it's the shifting from N to 1st that is causing my issues.... Mostly because the game takes no notice of the position of the shifter before the GO.
