Formula Gulf at Oschersleben GP, 13th December 7:30pm
OZFM :: Project Cars :: PCARS Racing :: Casual Events
Formula Gulf 1000 championship
Sunday, 13 December, 7:30pm
Oschersleben GP
Please abide by Slipstream Racing's code of racing etiquette
www.slipstream-racing.1127836.n5.nabble.com/Rules-of-Engagement-td48.html
Championship Points as follows
1st 2nd 3rd 4th 5th 6th 7th 8th 9th 10th
25 18 15 12 10 8 6 4 2 1
Points awarded per round. On a night there are 2 rounds, points will be awarded per race. On a night there is one longer endurance race only, double points will be awarded for that race.
If you miss a race round or weekend, you will awarded the next points down from last place finisher. If several people completely miss the race, then they will be awarded equal placed points.
Fuel tank limit will be 10l only at all times. This may require pitting for fuel during shorter races, not just for longer races. Set your pit strategy to fill back up to the 10l maximum tank limit, no more. You can top up with less fuel if you require less.
1st session starts at 7:30pm Australian Eastern Daylight Savings Time, room will be opened at 7:25pm
Please pick your car number beforehand, upon entering the room, check you have the correct number on your car. Races may be recorded and uploaded to youtube.
Qualifying session to be followed by short warm up, use as you wish - practice, adjust tune, drink top up, toilet break
Weather - fine
Time - 1000
Time progression - x5
Tyre wear - x3
Fuel use - Real
Race 1
15 minute qualifying
5 minute warm up 10
10 laps
Race 2
10 minute qualifying
5 minute warm up
22 laps
Oschersleben GP
Weather - fine
Time - 1000
Tyre wear - x3
Fuel use - Real
Race 1
5 minute warm up 10
10 laps
Race 2
5 minute warm up
22 laps
Steeljockey- Drivers licence
Re: Formula Gulf at Oschersleben GP, 13th December 7:30pm
Count me in mate. Though I might be late depending how we travel coming back from Sydney. Race 2 will be in for sure.
WoodyLizard
#11 Campbell Formula Gulf
WoodyLizard
Neilo05- Serious Racer
Be good to have you join us
Tempting BUT got to work out these damn FFB settings first. Changed since the last time I was on. Couldnt get anywhere last weekend. See how I go this weekend.
What wheel are you running? If you're using the TX with stock rim, I run all FFB at default except the following
deadzone at zero
speed sensitivity at 60
scoop knee at 50, scoop reduction at 49
If you have the GTE rim
scoop knee at 45, scoop reduction at 46
If you have a G920, try scoop knee at 47 and reduction at 21
deadzone at zero
Steeljockey wrote:What wheel are you running? If you're using the TX with stock rim, I run all FFB at default except the following
deadzone at zero
Yeah TX with stock 458 rim. Sweet as mate, i will have a go next time im on. I have sen you are pretty active on the PCars forum too.
Yeah I get around, I've seen you are pretty quick, not sure I'm happy with that lol
Hit me up for a chat or race when you see me on. Too many wheel adjustments can be confusing/counterproductive. Keeping it simple and getting FFB linear is the aim.
I also leave all car FFB stuff alone, Jack's settings are not helpful, and that is a big rabbit hole right there changing FFB for every car at every track. Fiddling with SoP is also very counterproductive to feeling what the car is actually doing unless you have a full motion sim.
Steeljockey wrote:Yeah I get around, I've seen you are pretty quick, not sure I'm happy with that lol
Haha yeah well the tuning is more my style than Forza - fast and slow damping for example is a treat!
I had dialled in a good setup before FM6 was released (when I was most active), all of the spindle setup remained the same across every car. I use those settings and its too heavy and it has this violent rack rattle that rips ones arms off. Ive never followed any of the recommended setups suggested by Spade, SMS or Thrustmaster. Some say its because my DOR is small....I disagree!
VERY IMPORTANT to leave your DOR at 900, you can change steering ratio to suit your preference per car. I'm working on some ratios for 360 and 270 DOR over at vmotorsport for reference. So far, most are 8 and under for a decent 360DOR
What I find is opposite lock requires tonnes of lock, turning not so much. Reason why ive always had small DOR, makes correcting oversteer easier.....
Do I or should I need to change anything on the wheel (via PC)?
wheel on xbox does not recognise any PC settings at all
I thought that, but read otherwise recently.
Have added you on XBL too.
just added you, chat invite sent if you are able
Gimmie 5 or 10 mins.
» Formula Gulf 1000 at Sakitto GP, Sunday 6th December
» Formula Gulf 1000 at Nurburgring GP
» Formula Mazda - Final Round - Yas Marina or VIR *VOTE* - Friday 13th May 2016
» P.CARS DTM 14/5 8:30pm
» Thursday casual night pCars racing starting 8:30pm
