F190 Round 1 - 1/1/2015
OZFM :: F190 Series
F190
Round 1
Circuit de Barcelona-Catalunya
Round 1
-Thursday 1/1/15 9pm nsw time
Qualifying session - 6 mins
Race 1 - 30 laps - Q Grid - no safety cars
Race 2 - 30 laps - reverse race 1 results grid - safety cars until lap 27
[You must be registered and logged in to see this link.] by [You must be registered and logged in to see this link.]
-History
The Circuit de Barcelona-Catalunya was built in 1991 and began hosting the Spanish Grand Prix that same year. Construction also coincided with the Olympic Games scheduled to take place in Barcelona the next year, where the circuit acted as the start and finish line for the road team time trial cycling event. The Circuit de Barcelona-Catalunya should not be confused with the Montjuïc circuit, which hosted the Spanish Grand Prix four times between 1969 and 1975 and, unlike the Circuit de Barcelona-Catalunya, is actually located within the city of Barcelona.
Because so much testing is done at this circuit, Formula One drivers and mechanics are extremely familiar with it. This has led to criticism that drivers and mechanics are too familiar with Catalunya, reducing the amount of on-track action.
When first used, overtaking was frequent as cars could follow closely through the last two corners and slipstream down the long straight. As aerodynamic balance became more critical, this overtaking method drastically decreased as the cars were unable to follow each other through the fast final corner due to turbulence created by the leading car. The 2007 season saw the first of the two final sweepers replaced with a slow chicane in an effort to improve overtaking. However, the redesign has not yet shown any effect.
The Circuit de Barcelona-Catalunya also plays host to many other racing series, including MotoGP. The chicane which was put in the penultimate turn for Formula 1 does not play a part in the track layout for Moto GP, and there are at least five points on the track (turns 1, 2, 4, 10, 14) where riders are known to overtake. As in Formula 1, turn one is arguably the most popular place for overtaking. The circuit is not known to produce copious amounts of overtaking, despite the long straights.
-Track Layout
The wind direction at the circuit can change drastically during the day, a significant factor given the importance of aerodynamics to modern Formula One cars. It is then hard to find a good setup since cars can have massive aerodynamic drag and understeer on one part of the circuit in the morning, but suffer oversteer at the same part of the circuit in the afternoon. A given tyre compound can work well when tested, but not so well a couple of months later. These changeable conditions can make for unexpected performances from some teams during the race.
-A lap in a Formula One car
Turn 1 is the main overtaking point at Catalunya, as it is a braking zone at the end of a long DRS straight. The inside and outside are just as difficult as each other for overtaking; if you can hold it around the outside of turn one, then you get the inside for turn two. The corners themselves make up a medium speed chicane — you brake rather late for turn one and shift down to gear two, and turn two is almost full throttle as you try and gain as much exit speed as possible. Turn 3 is a long, flat out (in some cars) right-hander that has a g-force of about four, and it leads onto a short straight before turn 4, the Repsol curve. Another right-hander, turn four is similar to Monza's Curva Parabolica — you brake and take an early apex (in third gear), before carrying lots of speed out of the exit. Turn 5 comes immediately after and is a slow left-hander taken in second gear which drops rapidly downhill towards the left kink of turn 6 which is ignored by F1 cars. Turns 7 and 8 make up a medium-speed, uphill, left-right chicane. Drivers brake and shift down to gear three, and must not run too wide as turn eight has a large kerb on its apex which could potentially damage cars' suspensions. Turn 9, Campsa Corner, is a very fast, sixth gear right-hander which is made incredibly difficult due to the fact that it is completely blind to the drivers. It is initially quite steep uphill but the exit is then downhill, making it blind, so it is quite easy to run wide onto the astroturf. The long back straight leads into turn 10 (La Caixa), a second-gear, left-hand hairpin, then turns 11 and 12, a left kink before a long, slow, third-gear right. The next section has been redesigned by German engineer Hermann Tilke to lower speeds onto the pit straight — which in turn increases overtaking opportunities and safety. Turn 13 is a tight, third gear right-hander and drivers have to quickly cross the circuit to take the racing line through the slow left-right chicane of turns 14 and 15, taken in second gear. Good traction is needed here as it determines speed down the pit straight. Turn 16 (New Holland) is a flat-out right-hander which takes you across the line.
-Racing History
The circuit has been the site of some memorable moments. In 1991, Ayrton Senna and Nigel Mansell went down the entire front straight side-by-side while duelling for second place, with Mansell eventually taking the position and ultimately the race itself. In 1994, Michael Schumacher managed to finish in second place despite driving over half the race with only fifth gear. In 1996, Schumacher took his first win as a Ferrari driver, after a dominant performance during a torrential rainstorm. The 1999 race was notable as there was only one reported overtaking move during the race. In 2001, Mika Häkkinen suffered a clutch failure while leading the race on the last lap, handing the win to Schumacher. At the 2006 event, Fernando Alonso became the first Spanish Formula One driver to win at his home country's track.
In 2008, Heikki Kovalainen left the track at 240 km/h (149 mph) after a wheel rim failure at turn 9. He managed to decelerate to 130 km/h (81 mph) when he hit the tyre barrier. He was temporarily unconscious and suffered a minor concussion, but a few minutes later, spectators were relieved when he gave a thumbs up.
Re: F190 Round 1 - 1/1/2015
Meanwhile clubs all around Australia were jamming to the sound of Coolios Gangsters Paradise, 1995's number 1 hit single.
Coolio - Gangsta's Paradise: [You must be registered and logged in to see this link.]
Aww yeah
may not pass the breatho test before the race
I approve
This Thursday 9pm nsw time
If you are having trouble starting your car, click this link
Nice video Stu!
TheAlfheim- Drivers licence
awesome racing tonight post up pics in the new thread for F190 pics
[You must be registered and logged in to see this image.]
» F190 Round 5 - 29/1/2015
» F190 Round 4 - 22/1/2015
» F190 Round 7 - 12/2/15
» F190 Round 9 - 26/2/15
» F190 Round 2 - 8/1/15
OZFM :: F190 Series
