OZFM
Would you like to react to this message? Create an account in a few clicks or log in to continue.
LOAD FAILED
LOAD FAILED Empty LOAD FAILED
Post by sempeR Fri Feb 28, 2014 5:15 pm
An unknown error occurred. Please try again later.
I have a horrible gut feeling that my fm5 save may be corrupted. That's the msg I'm getting after I 'press A to start'. Pretty much about completely loose my shite.
Help?
LOAD FAILED Empty Re: LOAD FAILED
Post by surferofthemind Fri Feb 28, 2014 5:30 pm
Hard reboot. Try that first.
I think you hold the (X) button on the front of console till it shuts right down then power off for a bit (rip the plug out of the wall, gently). Plug it in and start it up and see if you get the same error.
Also search out the FM.net forums as there is a few posts with similar issues and hopefully fixes.
Post by sempeR Fri Feb 28, 2014 5:45 pm
Haha that was the first thing i tried. I also tried battlefield, lost my campaign progress on that. Had a look on the Forza forum, couldn't find anything with the same description as my case. Not that it's not there I just couldn't find anything, as I'm sure I'm not the guy guy or gal who has had this problemo.
Post by sempeR Fri Feb 28, 2014 6:01 pm
Okay so iv come up with a theoretical solution. Delete my fm5 save from the console, no problem, data will sync with xbl and away I go.
This syncing data part is taking a while...
Post by surferofthemind Fri Feb 28, 2014 6:18 pm
Battlefield 4 just has an issue saving the campaign... I think I have done the first missions 3 times then gone back to multiplayer. Have not put it in for a while but last time it had no Continue Campaign option.
Post by sempeR Fri Feb 28, 2014 6:56 pm
OKay I had no idea about the bf glitch. My Forza save is all good now anyway. I suppose, the cloud is out there... (que X-Files theme)
I did end up finding a short thread on a random forum about someone with the same problem as me. He went and called xb customer support, deleted the game and reinstalled, then they couldn't help him anymore haha, useless friggs
Post by Guest Fri Feb 28, 2014 7:07 pm
hey semper. I had the exact same problem. i reinstalled fm5 but didnt work. You will need to reinstall your whole xbox and the whole game again. this will work. It is so annoying especially when you just want to do a few laps. but try that and you should be on your way. Cheers
Post by stikman Fri Feb 28, 2014 7:39 pm
I hope you lose your V8 tunes Wink
Post by Guest Fri Feb 28, 2014 9:16 pm
you wont lose any data that is saved. it will reinstall it all once youve installed the game
Post by sempeR Fri Feb 28, 2014 11:03 pm
I worked it out. Cheers dudes.
- Similar topics
