PCARS - FG1000 - Round 1 - Brands Hatch GP 02/06
+12
NinjaTaco22
sven brun
CosmicChimera
C RazyStingray
darkracing
Neilo05
Bretley
Diilusion
16 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
[You must be registered and logged in to see this image.]
Welcome to Round 1 of the OZFM Project Cars FG1000 Series
This week we are at
Track Guide
Lobby Schedule:
Race 1
Lobby Open: 8:30PM AEST
Practice: 30 minutes (8:35 - 9:05)
Qualifying: 10 minutes (9:05 - 9:15)
Warmup: 5 minutes (9:15 - 9:20)
Race 1: 8 laps (9:20)
Race 2
Qualifying: 15 Minutes
Warmup: 5 minutes
Race 2: 16 Laps
Lobby Splits
Lobby 1:
Ssemper
BretleyS
xCaders
Dillusion
oOFlubberOo
Dazza83
Hillcrest34*
FAA Beefnachos
K1NG RX7
Cosmic Chimera
Lobby 2:
Feralcobra
xXD3IIvII0NXx
NinjaTaco22
lll Auzzie lll
o Reaps o
Sven Brun
Woebegone6
Ningham16
MRN3Drifter
C RazyStingray*
TURDMASTER96
*Lobby Host
***PLEASE NOTE***
During qualifying if you are on a hotlap hit your headlights button to turn the red light on the back of your car on. This will tell others behind you that you are on a hotlap. In the event of rain it is requested that you turn this light on. If you do not have your light on and are involved in a collision this will be taken into consideration
Safety cars will be in use for the 2nd Race only, an incident must involve 2+ cars for a safety car to be called
Please make sure your connection is up to racing. If you feel you may be not be able to race safely with your connection it may be best for you to sit out. If you're connection is not stable enough to race and you cause incidents
The second race will have one mandatory pitstop
This week we are at
Track Guide
Lobby Schedule:
Race 1
Race 2
Warmup: 5 minutes
Race 2: 16 Laps
Lobby Splits
Lobby 1:
Ssemper
BretleyS
xCaders
Dillusion
oOFlubberOo
Dazza83
Hillcrest34*
FAA Beefnachos
K1NG RX7
Cosmic Chimera
Lobby 2:
Feralcobra
xXD3IIvII0NXx
NinjaTaco22
lll Auzzie lll
o Reaps o
Sven Brun
Woebegone6
Ningham16
MRN3Drifter
C RazyStingray*
TURDMASTER96
*Lobby Host
***PLEASE NOTE***
Race 1 Lobby and Weather Settings
Lobby Set Up
Structure & Sessions | Conditions | Restrictions |
Privacy - Private Number Of Laps - 8 Maximum Grid Size - 16 Max Number of Human Opponents - 15 Fill With AI Opponents - No Opponent Skill - Irrelavent Opponents All Identical Car - Yes Car Class - Current Rolling Start - No Practice 1 - 30 Minutes Practice 2 - No Qualifying - 10 Minutes Warmup - 5 Minutes | Weather Slots - 1 - Overcast Weather Progression - Real Time Date Type - 02 June 2015 Starting Time - 13:00 Time Progression - Real time | Force Interior View - No Force Manual Gears - No Force Realistic Driving Aids - No Allow ABS - Yes Allow Stability Control - Yes Allow Traction Control - Yes Damage - Performance Impacting Mechanical Failures - Yes Tyre Wear - Real Fuel Usage - Real Auto Start Engine - Yes Flags & Penalties - On |
Race 2 Lobby and Weather Settings
Lobby Set Up
Privacy - Private Number Of Laps - 16 Maximum Grid Size - 16 Max Number of Human Opponents - 15 Fill With AI Opponents - No Opponent Skill - Irrelevant Opponents All Identical Car - Yes Car Class - Current Rolling Start - No Practice 1 - No Practice 2 - No Qualifying - 15 Minutes Warmup - 5 Minutes | Weather Slots - 2 - Light Rain - Overcast Weather Progression - x2 Date Type - 02 June 2015 Starting Time - 15:00 Time Progression - Real time | Force Interior View - No Force Manual Gears - No Force Realistic Driving Aids - No Allow ABS - Yes Allow Stability Control - Yes Allow Traction Control - Yes Damage - Performance Impacting Mechanical Failures - Yes Tyre Wear - X4 Fuel Usage - Real Auto Start Engine - Yes Flags & Penalties - On |
Re: PCARS - FG1000 - Round 1 - Brands Hatch GP 02/06
any of the fast guys want to share a setup mine was pretty much default just adjusted final drive.
dazza83- Drivers licence
Lobby 1 - 8 laps, real tyre wear
Lobby 2 - 16 laps 5x tyre wear
CosmicChimera- Serious Racer
In - race 2 only
Neilo05- Serious Racer
its 2 races. race 1, is 8 laps. race 2, is 16 laps
dazza83 wrote:its 2 races. race 1, is 8 laps. race 2, is 16 laps
D'oh! I read it as lobby 1/2, not race 1/2
Yep x5 tyre wear is for race 2 only! Furthermore gird order will be set by qualifying on the night. Tuesday night was to determine lobbys Also I'll need a host for lobby 2 please
dazza83 wrote:any of the fast guys want to share a setup mine was pretty much default just adjusted final drive.
I would share a setup with you if i had one, but myself and im guessing everyone else at the top didnt have one but i could be mistaken. The only thing i have changed is the brake pressure.
Diilusion- Advanced Driver
most likely wont be there.... still waiting on my power brick to arrive. they say Wednesday I'll get it
if it does get here by tuesday I can host lobby 2
SETUP:
1 click up front downforce
5 clicks down all tyre pressures
2 clicks reward brake pressure
Forgot to close brake and radiator cooling but it might help before over heating. (Don't do this for racing unless you've found the most efficient balance between drag/cooling and horsepowers/heat)
HOT TIP: Concentrate on brake markers, line and execution before thinking setup. BUT if youre going to race in the rain, soften your anti roll bars and springs and turn down your brake pressure.
sempeR wrote:5 clicks down all tyre pressures
tyre pressures confuse me, im assuming lower pressure is good for a race because of better tyre wear, but for something like qual would you go higher pressures to heat up quicker get better grip but quicker wear.
(also sms devs said they tyre wear on these cars are bugged atm and are not wearing quick enough.)
i found this car hates the curbs, assuming rebound and spring etc can help with that.
I just like the feel better with lower pressures. Haven't experimented much more but I have my theories. You can smash kerb... If you hit it at the right angle, take just the right amount and at just the right speed, but only certain kerbs. Haha
Was unaware of bugs
Another hot tip. Deal with the kerbs by adjusting driving, not setup.
Was unaware of bugs
Kerbs depend on the track really, Brands has horrible kerbs so I avoid them like the plague, Watkins Glen, however, ride them kerbs (not the high ones obv) allllll daaaaaayyyy
Also in light of the tyre wear bug it may be worth upping tyre wear in the 2nd race to 7x, Though 5x did seem to wear
I'm keen to give sempers settings a go as I went in the opposit direction, upped pressures all round by 5 or 6 and dropped front wing by 3 and rear by 5. Didn't touch anything else. Im having enough problems adjusting to the wheel (1st time wheel user) to start playing with setup yet. Like semper said I'm trying to concentrate on driving properly with the wheel before trying to set the car up.
Bretley- L-Plater
Lobby settings updated for weather forecast
taken from
[You must be registered and logged in to see this link.]
taken from
Hey guys! Still need a host for lobby 2!
Out this week due to more work commitments.
hillcrest wrote:Hey guys! Still need a host for lobby 2!
still waiting on my power brick......grrrrrrrrrrrrrr
Ive just realised that I have double booked myself with a committee meeting so I will not be able to attend The first round.
darkracing- Drivers licence
mad DANNO 29 wrote:hillcrest wrote:Hey guys! Still need a host for lobby 2!
cheers danno, just trying to tee something up incase it doesn't come tomorrow
I haven't registered yet, but if a host is still needed by this time tomorrow i can do it for you
C RazyStingray- Admin
C RazyStingray wrote:I haven't registered yet, but if a host is still needed by this time tomorrow i can do it for you
Legend!
missing tonight.
» PCARS - FG1000 - Qualifying Round - Brands Hatch GP 26/05
» Round 1 - Brands Hatch Indy
» PCARS - FG1000 - Round 5 - Brno - 14/07
» PCARS - FG1000 - Round 3 - Imola 30/06
» PCARS - FG1000 - Round 2 - Zolder 22/06
Page 1 of 3
