Tuning guides
2 posters
Tuning guides
Just wondering if anyone has any good resources that go through tuning for dummies?
Would like to get a better understanding of what values I should be aiming at for the various components eg with adjusting the camber etc.
And in particular when using the telemetry should I be looking at the inside or outside tire temps when adjusting camber?
mog0001- L-Plater
Re: Tuning guides
Centre tyre temperature will give you an indication of the tyre temperature for grip. Outside temperature should be less than the inside temperature, in particular with the fronts, by 2-5 degrees Celsius depending on track. I usually run rears fairly close inside to outside running much less camber, but also much less roll bar on the rear at the same time for RWD and 4wd cars.
If you have istuff, you could look for Forza tuning guides for FM4 and 5, not sure if there has been an update for 6 yet.
For pCars there is a good basic tuning guide for springs and dampers, but you need to run it on excel, so a bit fiddy putting in setups.
Steeljockey- Drivers licence
» RWD Drag Tuning and Launching Tutorial. A few PPRT Tuning secrets revealed.
» I'm Looking for a Tuning Buddy or Tuning Buddies!
» Tuning help!!!!
» Tuning Guide
» Burnout Car Tuning
» Tuning help!!!!
» Tuning Guide
