F190 Round 2 - 8/1/15
OZFM :: F190 Series
F190
Round 2
Circuit de Spa-Francorchamps
Round 2
-Thursday 8/1/15 9pm nsw time
Qualifying session - 7mins
Race 1 - 14 laps - Q Grid - no safety cars
Race 2 - 14 laps - reverse race 1 results grid - safety cars until lap 12
Over the years, the Spa course has been modified several times. The track was originally 15 kilometres (9 mi) long, but after World War II, the track had some changes. In 1930 the chicane at Malmedy was eliminated and bypassed, making the course even faster, but the chicane was re-installed in 1935, albeit slightly different. In 1939, "Virage de Ancienne Douane" was eliminated and cut short, thus giving birth to the Eau Rouge/Raidillon uphill sweeping corner. In 1947, the chicane at Malmedy was again eliminated and bypassed, and was made part of the Masta Straight. The slight right-hander that was originally Holowell (the corner before Stavelot after the second Masta Straight) was eliminated. And finally, instead of going through a slight left-hander that went into the town of Stavelot and a sharp right-hander at a road junction in Stavelot, a shortcut was built that became a very fast, very wide right-handed turn that bypassed Stavelot. All these changes made the final configuration of the old Spa circuit 14 km (9 mi) long. All these changes made Spa the fastest open road circuit in the world, and in the final years of the old circuit, drivers could average 150 mph (241 km/h) on the circuit. The biggest change, however, saw the circuit being shortened from 14 km (9 mi) to 7 km (4 mi) in 1979. The start/finish line, which was originally on the downhill straight before Eau Rouge, was moved to the straight before the La Source hairpin in 1981. Like its predecessor the new layout still is a fast and hilly route through the Ardennes where speeds in excess of 330 km/h (205 mph) can be reached. Since inception, the place has been famous for its unpredictable weather. Frequently drivers are confronted with one part of the course being clear and bright while another stretch is rainy and slippery.
The circuit probably demonstrates the importance of driver skill more than any other in the world. This is largely due to the Eau Rouge and Blanchimont corners, both which need to be taken flat out to achieve a fast run onto the straights after them, which aids a driver in both a fast lap and in overtaking.
The most famous part of the circuit is the Eau Rouge / Raidillon combination. Having negotiated the La Source hairpin, drivers race down a straight to the point where the track crosses the Eau Rouge stream for the first time, before being launched steeply uphill into a sweeping left-right-left collection of corners with a blind summit. Properly speaking, the Eau Rouge corner is only the left-hander at the bottom. The following right-hander that leads steeply uphill, which was introduced in 1939 to shortcut the original hairpin "Ancienne Douane", is called "Raidillon". The corner requires a large amount of skill from the driver to negotiate well and the long straight ahead often produces good overtaking opportunities for the best drivers at the following "Les Combes" corner. The corner was tighter and narrower (it was made wider in 1970, when the circuit was updated) on the old circuit than it is today on the current circuit, which made it considerably slower.
The 2005 and 2006 F1 World Champion Fernando Alonso explains: "You come into the corner downhill, have a sudden change [of direction] at the bottom and then go very steep uphill. From the cockpit, you cannot see the exit and as you come over the crest, you don't know where you will land. It is a crucial corner for the timed lap, and also in the race, because you have a long uphill straight afterwards where you can lose a lot of time if you make a mistake. But it is also an important corner for the driver's feeling. It makes a special impression every lap, because you also have a compression in your body as you go through the bottom of the corner. It is very strange – but good fun as well."
The challenge for drivers has always been to take Eau Rouge-Raidillon flat out. Regular touring cars can take the corner at 160–180 km/h, Formula One at over 300 km/h. This is due to the huge amount of downforce on the cars. World Champion Jacques Villeneuve once spoke of the effects of downforce saying that to get through the corner they have to go faster as the faster the car is going the more downward force there is, thus explaining the phenomenon of Eau Rouge flat out.
Still, a loss of control in this section often leads to very heavy shunt as usually the rear-end of the car is lost and the impact is most of the times lateral. Eau Rouge has claimed several victims over the years, including Stefan Bellof in a Porsche sportscar, Guy Renard during the 24h of Spa-Francorchamps in 1990 in a Toyota Corolla GT and also caused Alex Zanardi's in 1993 and Jacques Villeneuve's spectacular off in qualifying in 1999, which he described as "My best-ever crash", followed by his team-mate Ricardo Zonta's similar accident, leading cartoonist Jim Bamber to show BAR boss Craig Pollock telling Zonta: "Jacques is the quickest through Eau Rouge, so go out there and do exactly what Jacques does…"
Following the deaths of Roland Ratzenberger and Ayrton Senna at Imola in 1994, the following F1 races saw the introduction of chicanes made up from stacked tyres. The entry to Eau Rouge was obstructed in such a way in 1994, although it was returned to its previous glory the following year. The corner was slightly modified for 2002, but still retains its character.
Testimony to the fame and beloved character of the Eau Rouge corner can be found in fan reaction to the Istanbul Park circuit in Istanbul, Turkey. When fans first got to see the course configuration at the start of the weekend of the 2005 Turkish Grand Prix, many noted that an uphill kink on the back straight was very similar to Eau Rouge; many jokingly dubbed the kink "Faux Rouge" (a pun on the name of the original Spa corner using the French word "faux", meaning "false").
The Blanchimont turn is one of the most fearsome turns in Formula One. This high-speed left-hand turn, present in both the old 14 km circuit and the new, shorter, 7 km track, is the final sweeping corner of the track before the Bus Stop chicane, which leads to the pit straight.
This turn and the approach to it have caused serious accidents over time, the most recent being in 2001, when Luciano Burti lost the front wing of his Prost due to a clash with Eddie Irvine's Jaguar, losing front downforce and steering, leaving the track at 185 mph (298 km/h) and piling into the tyre wall, the impact knocking him out and burying the car into a mound of tyres. Problems have also occurred in lower classes of racing with Tom Kristensen having a very violent crash in a Formula 3000 car in 1997 after running wide on the entry to the Blanchimont turn and subsequently hitting the wall effectively throwing the monocoque back out in the middle of the track, where it was hit by numerous cars before coming to a complete halt.
The run-off area is narrower than in other turns taken at this speed, plus the fact that behind the protective barriers there is a 7–8 meter drop. This is the first turn taken by the cars after the new track rejoins the route of the old 14 km track. Blanchimont was also the scene where in 1992 after Erik Comas had crashed heavily during Friday's session, Ayrton Senna stopped, disembarked his car and sprinted to help the injured driver, with other cars driving past at racing speeds.
Re: F190 Round 2 - 8/1/15
Having some difficulty with my internet provider not being able to do their job, unsure if i will be able to race this Thursday so il need someone to take photos of I don't cheers, haven't been able to get any photos of round 1 either
Nevermind il be there, you all better be ready
» F190 Round 6 - 5/2/15
» F190 Round 3 - 15/1/15
» F190 Round 10 - 5/3/15
» F190 Round 12 - 19/3/15
» F190 Round 8 - 19/2/15
OZFM :: F190 Series
