Open tunes for V8 series 10
Page 2 of 2 Previous  1, 2
Re: Open tunes for V8 series 10
Post by TheAlfheim on Mon Aug 25, 2014 8:30 am
Hi Dux... I loaded up your tune over the weekend - it drives great! Thanks heaps for sharing it! Much appreciated
TheAlfheim
Drivers licence
Post by mystery on Mon Aug 25, 2014 8:19 pm
From those spring rates you must have a weird driving style Ha Ha ... just joking thanks for sharing
mystery
Post by Sly Dux on Mon Aug 25, 2014 8:33 pm
mystery wrote:From those spring rates you must have a weird driving style Ha Ha ... just joking thanks for sharing
Yeah it seems odd but is the easiest way to balance the power. Its not just my driving style thats weird g man Razz
Post by ThresholdAU on Thu Aug 28, 2014 3:55 pm
I'm still having issues find the right brake settings.
45% seems to stop my ABS-less noobness locking it up but I feel im braking much earlier then other racers and sometimes still come in too hot from the straight.
Should I adjust it higher and learn some tough lessons about being gentler on brakes?
Any tips , I'm not used to non-ABS
ThresholdAU
Drivers licence
Post by Nick Bear on Thu Aug 28, 2014 5:22 pm
Whats 45% the brake balance or the brake force?
Nick Bear
Nick Bear
Post by ThresholdAU on Thu Aug 28, 2014 5:26 pm
Force, I understand that effects how hard you can press before lock up vs the braking distance
ThresholdAU
Drivers licence
Post by Nick Bear on Thu Aug 28, 2014 5:33 pm
Yeah force is usually a feel thing for most people I would raise it up and try get a feel for it I have mine anywhere from 85-120 depending on the car
Nick Bear
Nick Bear
Post by Mitch on Thu Aug 28, 2014 5:44 pm
Yeah it will take a while to get used to - for me i found there were a combination of factors, including force, deadzones and setup. 45% Brake Force seems to be too low IMO.
Post by Mitch on Thu Aug 28, 2014 6:00 pm
On FM1 back on the original Xbox, when I first learnt not to use ABS (on the controller) I just done some straight line accelerating and heavy braking until i got used to the where the threshold was in the triggers. My driving style kinda grew from there. When I started to use the wheel on FM2, I just done the same thing!
If you constantly find yourself underbraking, your pressures are probably set too low. Just remember too that you cant carry the same braking pressures into a corner like you can in a straight line.
So many tips to give!
Post by Dektra on Thu Aug 28, 2014 7:24 pm
No you can't carry the same brake pressure into a corner as a straight. If you are you are underbraking on the straight.  You're fronts will lock if at critical point and the wheel is turned
Post by Sly Dux on Thu Aug 28, 2014 10:33 pm
forza 5 is big on not braking and turning. try braking in a straight line, letting off then turning in. braking and turning=lockups & sand traps
Post by ThresholdAU on Fri Aug 29, 2014 8:06 am
Some sound advice here, i'll get back to those practice laps and try to sort it out.
ThresholdAU
Drivers licence
Post by Mitch on Fri Aug 29, 2014 12:51 pm
Hey Threshold, send me a FR if you want and if you see me online, Im always up for a bash. We can have a yap and throw you a few pointers ect.
Post by hillcrest on Fri Aug 29, 2014 1:08 pm
I generally run about 120-130% brake pressure, but thats personal preference. when I first started not using ABS i used about 90% pressure and just practiced until I was confident. Once you're feeling confident by yourself definitely try doing some single player or multiplayer races to get used to doing in a racing environment.
Post by TheAlfheim on Mon Sep 01, 2014 10:18 am
ThresholdAU wrote:Any tips , I'm not used to non-ABS
Hi Threshold....
I learned to race without ABS for this series - my first time even trying it. I watched some videos on youtube, and those guys had pretty high brake pressures (sometimes greater than 150%!).
I'm no expert, but two things helped me;
1: I watched the braking red bar in the lower right of the screen. Full brakes should be a lockup. After a few goes, you should learn how much to press the trigger before a lock up happens.
2: I did this in a private game, with a lot of practice on the main straight. Its kinda hard to watch the red bar as you're barreling into a corner! After a while, you get a feel for it. You'll still have the occasional panic moment with too much brake and a lock up.
As others have said, braking and turning is much harder (you need a lot less brake). Also, the trigger thresholds (on advice from somewhere else, I set mine to 0/100 for off and full).
Let me know if this doesnt make sense.
And if people know more, please correct me!
Alf
TheAlfheim
Drivers licence
Post by dazza83 on Mon Sep 15, 2014 1:34 am
any changes we should make to this tune, for this weeks race.
dazza83
Drivers licence
Post by Sly Dux on Mon Sep 15, 2014 7:24 am
hey dazz try dropping the spring rates by about 40 kg front and rear i didn't change too much. just softened it up trying to get more front at nurburg. TBH i really havent touched it since tuesday but if it soaks up the kerbs it will be fine for silverstone. Make sur e your ride ight is h igh enough to avoid bottoming out.
