Open tunes for V8 series 10
Page 1 of 2 1, 2  Next
Post by Sly Dux on Wed Aug 20, 2014 9:54 pm
Yo peeps! Had a bit of an idea last night after quali, some of the guys said they had trouble with tuning. Hopefully it helps a few of you find some time. I have done very similar times in both tunes but i beleive the holden is more forgiving as a race car. So here they are  Very Happy  Enjoy!! They are also shared under ozfm if you cant be bothered tuning and just wanna have a run in them
VE commondoor:
Tire pressures:
Front: 2.0 (6 clicks back from 2.1) Rear: 1.9 (9 clicks forward from 1.Cool
Gearing:
3.10 final drive and stock gears
Camber:
Fr: -3.5 R: -3.0
Toe:
Fr: 0 R: -0.3
Caster: 5.0
Roll Bars:
Fr: 23.23 R: 21.75
Springs:
Fr: 139.5 R: 100.3
Ride Height:
Fr: 12.7 R: 8.4
Rebound:
Fr:9.0 R:8.9
Bump:
Fr: 6.6 R: 5.5
Aero:
Fr:140 R:170
Brakes:
Stock settings
Diff:
Acc: 44   Dec:12
Time: 1.51.121
Ford FG falcoon:
Tires:
Fr: 2.0 (3 click from 1.9)  R: 1.9 (2 clicks from 1.Cool
Gearing:
Final drive 3.10 final drive stock everything else
Camber:
Fr: -3.5  R: -3.0
Toe:
Fr: 0.1  R:-0.2
Caster: 5.5
Roll Bars:
Fr: 16.53  R:17.85
Springs:
Fr: 182.1  R:104.2
Ride Height:
12.7 front and rear
Rebound:
Fr: 8.5  R:8.2
Stiffness:
Fr: 6.0  R: 5.5
Aero:
Fr: 140  R: 160
Brakes:
Stock setup
Diff:
Acc: 60  Dec: 11
Time: 1.50.8xx
Hope it helps somebodies that may be struggling. My biggest tuning tips would be learning how damping affects the stability of the car and how to balance them against each other, Roll bars are good for tweaking and turn in and oversteer. Also a v8 supercar is like a gun. If you just pull the trigger you gonna miss, Squeeze that sh#t slowly and watch your targets drop
Re: Open tunes for V8 series 10
Post by Evil xr 1200 on Wed Aug 20, 2014 10:35 pm
Cool Sly Dux thanks I will give it a go more up the top the more awesome the series will be
Evil xr 1200
Evil xr 1200
Drivers licence
Post by dazza83 on Wed Aug 20, 2014 11:05 pm
gave it a go after 3 laps would have qualed 9th damn you being 1 day late Razz
btw front camber is meant to be - im assuming
opps read time wrong was good enough for 9th.. still a good tune
dazza83
Drivers licence
Post by Evil xr 1200 on Thu Aug 21, 2014 9:12 am
It will help me because I am right at the bottom I will tune it today and tell you what time I ran.
Evil xr 1200
Evil xr 1200
Drivers licence
Post by sempeR on Thu Aug 21, 2014 1:19 pm
Get around this guys. Sly puts in a lot of time, effort and frustration to get these tunes to where they are. If you give them a go, give him some feedback! Smile
I don't run a Sly tune, but I ran his awhile ago and felt some good things, then changed mine up afterwards. Thanks dude!
Post by dazza83 on Thu Aug 21, 2014 5:36 pm
Camber:
Fr:3.5 R: -3.0
for the ford is it meant to be 3.5 or -3.5 ? i always thought chamber should be -
doing it the way you wrote makes the car impossible to turn in.
dazza83
Drivers licence
Post by FAA Beefnachos on Thu Aug 21, 2014 6:11 pm
dazza83 wrote:Camber:
Fr:3.5  R: -3.0
It's -3.5 and -3.0 mate. Always in the negatives with camber !  Very Happy
FAA Beefnachos
FAA Beefnachos
Post by CosmicChimera on Thu Aug 21, 2014 6:21 pm
Thanks heaps Sly for putting these up - very keen to give them a go. I've really struggled with tuning this series.
CosmicChimera
CosmicChimera
Post by C RazyStingray on Thu Aug 21, 2014 6:49 pm
Fixed camber values in OP to avoid confusion
C RazyStingray
C RazyStingray
Admin
Post by Sly Dux on Thu Aug 21, 2014 10:07 pm
Sorry about the camber fails. Always negative
Post by Evil xr 1200 on Thu Aug 21, 2014 11:17 pm
Still have not used your tune yet I am very appreciative  of the tune I can see that it would take a lot of time
Regards
Michael
Evil xr 1200
Evil xr 1200
Drivers licence
Post by CosmicChimera on Fri Aug 22, 2014 9:45 am
After my sad attempt at quali, I've worked on my own tune and got down to consistent mid-1:53.xx - Sly your tune is a lot stiffer than mine, but I've applied your alignment and tyre pressures and ARB F/R ratio to my tune and am now in the mid 1.52.xx range. Good stuff.
CosmicChimera
CosmicChimera
Post by mad DANNO 29 on Fri Aug 22, 2014 1:44 pm
Thanks heaps Sly.
I know some of you spent a tonne of time on these tunes and to share it to the OZFM community is awesome.
I will give it a go tonight and see if I can better my shameful qualifying times.
I tend to always have issues with under steering so may need to adjust it a little probably
Been a learning curve not using TCS.... the V8 was the only car I used it on... but feels a lot better when I can get it right.
Once again a massive thankyou
Technical Director
Post by feralcobra on Fri Aug 22, 2014 7:11 pm
Thanks sly I tried it this arvo and was heaps better I would recommend if you can't tune give this a go keep up the great work sly
cant drive  [You must be registered and logged in to see this image.]  cant shoot  [You must be registered and logged in to see this image.]  but its all good  [You must be registered and logged in to see this image.]
Post by hillcrest on Sat Aug 23, 2014 6:41 pm
1 hot lap with this tune and I'm already .300 better than my fastest lap. Holy crap, I spent over 200 laps trying to crack better than a 1:52:9xx and hit a 1:52:6xx off the bat, and it wasn't even a good lap haha
Thank you so much sly haha
Post by Sly Dux on Sun Aug 24, 2014 8:57 am
No worries. I accept cash donations, also cartons are acceptable but only if they are cold ha ha
Post by Mitch on Sun Aug 24, 2014 9:15 am
+1 for tune share.
Are you on a wheel or controller Sly?
Post by Sly Dux on Sun Aug 24, 2014 2:15 pm
Controller man tap tap tappin away  Very Happy
Post by Mitch on Sun Aug 24, 2014 3:12 pm
Hehehe!!
On the wheel, I thought it had great turn in, low-speed grip was good but I was getting some mid-corner push - I suspect it was from some rear body roll but I think it would be down to the device used and the driving style - controllers are perhaps more of a "point and shoot" and need more rear squat than someone on the wheel...?? But it certainly works and I will certainly look at it to see where I can improve my low-speed grip.
If anyone had the chance in doing so, I might join the cause and post up for sharing and feedback. Been working on it today where I've cracked the 1:50s (okay, juust - 1:50.999 - LB time). Still getting my head around the tuning on FM5 as Ive only been back on the game and wheel for a month or so.
Post by Mitch on Sun Aug 24, 2014 3:38 pm
Not taking anything away from Sly's tune and instigating the topic - great stuff dude. My contribution for those interested, and welcome the feedback.
Ford Falcon FG
Best of 1:50.999  - have had a few green sectors since my best so far.
Tyres: F: 2.0 (two clicks "up" from 1.9)
Tyres: R: 1.9 (two clicks "down" from 2.0)
Gearing: FD: 3.10 followed by 2.35 | 1.97 | 1.63 | 1.40 | 1.21 | 1.07
Camber: F: -2.2 | R: -2.1
Toe: F: +.01 | R: -0.2
Caster: 6.7
ARB: F: 18.43 | R: 22.95
Springs: F: 149.2kg | R: 71.7kg
Ride: F: 12.2cm | R: 12.2cm
Rebound: F: 8.6 | R: 6.3
Bump: F: 6.6 | R: 3.0
Aero: F: 137kg | R: 177kg
Brake: 50% (pressures your choice)
Diff: Acc: 45% | Dec: 20%
Last edited by Mitch on Sun Aug 24, 2014 8:59 pm; edited 1 time in total (Reason for editing : So I can tell the folks what car I was tuning (you dumb shit Mitchell)....)
Post by Sly Dux on Sun Aug 24, 2014 8:56 pm
Hey mitch good stuff man  Very Happy
Buuut is the the tune for the ve or fg?
Post by Mitch on Sun Aug 24, 2014 8:58 pm
--addressed!!
Falcon my friend..!!
Post by sempeR on Sun Aug 24, 2014 11:54 pm
Great stuff! Wheel user's rejoice!
Last edited by sempeR on Mon Aug 25, 2014 12:31 am; edited 1 time in total (Reason for editing : lol spelling correction)
Post by TheAlfheim on Mon Aug 25, 2014 8:30 am
Hi Dux... I loaded up your tune over the weekend - it drives great! Thanks heaps for sharing it! Much appreciated
TheAlfheim
Drivers licence
Post by mystery on Mon Aug 25, 2014 8:19 pm
From those spring rates you must have a weird driving style Ha Ha ... just joking thanks for sharing
mystery
mystery
